WTB Polaris 800 RER Retrofit
sooboy
I am looking at putting electronic reverse on my 02 800 polaris engine.
Is there anyone out there who has the necessary items to get this done.
Flywheel,stator,trigger coil,ecm?
What you need is just the stator w/ coil and the CDI, as well as a reverse helix. The flywheels are the same. I have the CDI for sale, and I think the stator also, $250 plus shipping and they are both yours.
look into e-bay
I have seen several on e-bay from time to time with clutch and all related items
PERC
The stator is a 4010297 and was found on 2001-2006 big block liberties. (700-800) so your stator is fine.
flwyeel is different, 18 degree, 4010677 and is stock on 2003-2005 big blocks.
Need a CDI and the associated harness that has the gray wire that connects to the button on the left hand control. You can also use the Pro X reverse button that mounts to the hadlebar. It's a momentary connection, just like the other control. I sends a connection to ground to the CDI to initiate the reverse sequence.
The oil pump is different too. Use the Polaris cross reference web page to check for models that the flywheel is on becasue I found a newer 500 with PERC that had the 18 degree flywheel, same part number.
Team clutch with helix with ER in the designation is the last item.
Will be doing my sons 2002 800 shortly and then we'll sell the mechanical reverse. i picked up the harness, CDI with DET, CDI harness, DET sensor, oil pump, and handle bar control. We had already upgraded to the Team cluthc with appropriate helix in anticipation of adding PERC.
Blue Dave on e-bay (Devils Lake ND) sells conversion kits but the XC doesn't use the Team clutch and doesn't include the flywheel. I'm not sure if the 14 degree stock flywheel works or not. they aren't expensive if you find one used.
Thanks for the info,just bought one off of e-bay but doesnt look like the flywheel is included.
I need an 18deg flywheel wright?
PERC/RER
Yes. I've not tried it (getting it to go backwards with the new CDI and harness) without changing the flywheel but why else would they have changed in 2003 to the new flywheel? The PERC oil pump also has a number 18 stamped on the lever arm that the throttle cable attaches to. It's the only difference I can see between the pumps to distinguish them.
