39 grams of unbalance
I will not talk about what Ski-Doo is doing on their 2012 800cc at this time.
I'm doing just like a 454 chev. or 428 ford External Engine Balance. Basically the clutch and new mag. rotor become part of crank assy. The 800R motor are real close on their mass producing the crank assy. Again the 115 grams of unbalance and angle of unbalance is given to me by my German made state of the art balance machine. The Engine Kit is not a perfect balance but is with in 10 grams or less on all 2007 - thru 2011 motors (800R and etec 800).
Part of my patent process is I'm the only one in the world spinning the rods, pistons, etc. right in the motor case. You just send your primary clutch. I first balance it in a two plane set-up and then I place it on my 2010 sled along with a per balanced rotor for the mag. side then I set-up the balance machine on my sled and run it at about 2500 rpm and using the clutch and mag. rotor balance the crank without even removing it from the motor case.
The reason for spin balancing anything is to take out the imperfections of manufacturing and one of those imperfections is RUN OUT. Call me and ask about the 900 Arctic Cat that I balanced back in 2005 it's a perfect example of run out issues.
And this RUN OUT issue is just one reason for spin balancing any rotating mass. On these cranks distribution of mass in the crank, pistons ,rods, etc. is where the unbalance is coming not .003 or .004 RUN OUT.
This new technology has only been out for a few years. I no longer have to take the crank out and tear it apart and put bob-weighs on it. That technology of the pass is only a best guess. My patent pending process is NOT a guess.
And if you send the core motor I can take all of the unbalance out of the motor or crank and clutch assy.
I'm not going to give out all my secrets but EVERY SINGLE MOTOR NEEDS TO SPIN BALANCED. There is no balance marks (holes or pins or any thing showing the three manufacturer's doing any spin balancing on any motor). Including 2012 Ski-Doo, Polaris, or Arctic Cat.
If you would just call I will truly explain my process in detail over the phone.
