Definitely the worst clutch I have ever balanced.
This is just a demonstration of how far out a clutch can be. This Ski-Doo 1000 cc is at an unbalance of 39grams. I will show you the clutch before and then I use temporary weights to give you an idea of what balancing the clutch can do for you. This is not the finished product just an example of the process I do before I add or subtract the weight to adjust the clutch to make it balanced, typically we remove weight to obtained a balanced clutch.
Check this out on youtube:
http://youtu.be/t48OmERPSy0
