J
jtblaster
ACCOUNT CLOSED
u r on snowest again huh"
LMAO! Did you replay and say H3LL YA!
I learn alot of stuff by wandering around on here.
I think i am addicted
i had to text my old man and ask if the sled i ride had the stab/sway bar on or off - he replied "off - u r on snowest again huh"
Also, generally speaking, if you are right handed you will have an easier time mastering sidehilling on your left side first.
Interesting to know. I'm not very good at sidehilling on the right side
Throttle & Weight: I throttle up and weight the hill side of my sled first and foremost. I then engage in a slight counter steer once I have a bit of momentum built up - this lays the sled over a bit more into the hillside. This will actually become nearly one fluid movement once you get comfortable with throttle control and weighting your sled.
Stance & Poise: Most gradual sidehills I can do with a normal stance and weighting the hill side foot - it's when I cut hard that I may need to stand on one side or swing a leg out. However, on older model sleds that do not respond as well to rider input, you may need to put both feet on the hill side of the sled in the beginning. Remember to keep your back straight and butt in - I often see beginners hunched over and sticking there butt out thus keeping their weight lower.... instead, stand tall - your leverage is up high. Yes, taller people have an easier time leveraging their sled I'm sure but with the right techniques (weighting the sled properly, poising properly and good throttle control) - you can do it just as well! (I'm 5'4 and 120 lbs.)
When it comes to throttle control - not much is really needed, just enough to get that track spinning good enough to help dig you in a bit and stick you to the hillside.
You can practice weighting your sled and throttle control on flat ground - this is where I'd start - weight one side of your sled and gas it in a straight line, dont try to carve yet - just get a feel for riding the "edge". Your front end should feel lighter and the opposite ski should pick up slighty. At this point, you are riding your "edge" and this can be all you need for a gradual sidehill. Again, get comfortable with throttle control and weighting your sled - this is what it's all about! (I really like a better term for snowmobiling is "weight-mobiling".)
Than start to practice sidehilling on gradual open hillsides with no consequences below. And just keep doing it until you start to feel it. It comes with practice. Dont let trenches scare you - think of your track as a chainsaw - it will rip right through them if your committed to hold the throttle on but hesitate and they can toss you around. It is always best to try and pick your own line anyway.
I should have printed this out and brought it with me to refer back to! But all the advice was helpful - it hard not to want to stick your butt out there!! But I tried to take all the advice - especially - the play/practice everytime you can - I had my vest on & teather cord attached - sure is allot easier on the old mans 2008 m8 man that sled is friendly - but of you can do stuff on an older sled then when you upgrade it should be a little easier right? I also practiced slower with more control - that was a little harder than just goosin it & gettin a ski up - thanks everybody
Another thing that I'd like to bring back up again is the fact that a women's instinct to question, analize and evaluate risk is something that can work against us out there! It typically causes hesitation and hesitation is what gets you stuck or in other situations you dont want to be in. You have to be confident and commit yourself! There are obvious risks out there you should be analyzing like hills that could slid and kill you! But when your just boondocking through the powder, be more relaxed, focus on technique and concentrate on your line from point A to point B, not on the obstacles that you "might" hit or get stuck in along the way. And of course, the more you ride, the more confident you will get out there.
