Why do you say you can't connect router to router? Ahhh, maybe I see where you are going. This creates an "access point" rather than a router.
by
Bradley Mitchell
Updated October 01, 2016
While most
home computer networks only use one router, adding a second router makes sense in a few situations:
- Upgrading a wired network to also support wireless devices
- Extending the wireless range of a home network to reach dead spots
- Networking a wired device that's too far away from the original router
- Creating a separate subnetwork within the home to stream video among some devices without bogging down connections to others
Making it all work requires just a few steps.
Positioning a Second Router
When setting up a new router, place it near a Windows PC or other computer that can be used for the initial configuration. Both wired and wireless routers are best configured from a computer connected via
Ethernet network cable. The router can be moved to its permanent location later.
Connecting a Second Wired Router
A second (new) router that doesn't have wireless capability must be connected to the first (existing) router via an
Ethernet cable. Plug one end of the cable into the new router's
uplink port (sometimes labeled "WAN" or "Internet"). Plug the other end into any free port on the first router other than its uplink port.
Connecting a Second Wireless Router
Home wireless routers can be connected to each other via Ethernet cable the same as wired routers. Connecting two home routers via wireless is also possible, but in most configurations
the second one will only be able to function as a wireless access point instead of a router.
The second router must be set up in
client mode to utilize its full routing functionality, a mode that many home router's don’t support. Consult a specific router model's documentation to determine whether it supports client mode and how to configure it.
Wi-Fi Channel Settings for Wireless Home Routers
If both the existing and second new routers are wireless, their Wi-Fi signals can easily interfere with each other, causing dropped connections and unpredictable network slowdowns.
Each
wireless router utilizes certain Wi-Fi frequency ranges called
channels, and signal interference occurs whenever two wireless routers in the same house uses the same or overlapping channels.
Wireless routers use different Wi-Fi channels by default depending on the model, but these settings can be changed via the router's console. To avoid signal interference between two routers in a home,
try setting the first router to use channel 1 or 6 and the second to use channel 11.
See also -
Change the Wi-Fi Channel Number to Avoid Interference
IP Address Configuration of a Second Router
Home network routers also have default
IP address settings depending on their model. The default IP settings of a second router do not require any change unless it is to be configured as a
network switch or access point.
Using the Second Router as a Switch or Access Point
The above procedures enable an additional
router to support a
subnetwork within a home network. This is useful when wanting to maintain an extra level of control over certain devices, such as placing extra restrictions on their Internet access.
Alternatively, a second router can be configured as an
Ethernet network switch or (if wireless) an
access point.
This lets devices connect to the second router as normal but does not create a subnetwork.
For households simply looking to extend basic Internet access plus file and
printer sharing to additional computers, a no-subnetwork set up is sufficient, but it does require a different configuration procedure than above.
Configuring a Second Router Without Subnetwork Support
To set up a new router as a network switch, plug an Ethernet cable into any free port of the second router other than the uplink port and connect it to any port of the first router other than the uplink port.
To set up a new wireless router as an access point, configure the device for either
bridge or
repeater mode linked to the first router.
Consult the second router's documentation for the specific settings to use.
For both wired and wireless routers, update the IP configuration:
- Check the second router's local IP address and change it if necessary to ensure it is within the address range of the network as configured on the first router and not conflicting with any other device on the local network.
- Set the DHCP address range of the second router to fit inside the address range of the first router. (Alternatively, disable DHCP and manually set the IP address of each device connected to the second router to fall within the first router's range.)
