http://www.speedwerxstore.com/index.php?l=page_view&p=lesledpackages
Another company doing aftermarket package...it is a/c again, but mark my words...ski-doo, and Polaris will be soon to follow!! With various aftermarket companies putting together proven packages...This is going to advance our sport faster than ever. I see it as a win, win for everyone!!
wheres my waders.its getting deep in here.
An affordable fix for belt drives will be available for pre-order next week...
Belts are less than OEM, different gearing options available.
Is it any stronger? Will it withstand heat any better?? What all makes up the kit belt, pulleys, tensioner?
Another issue is the tooth pitch on the belts. More teeth per inch = better belt "traction" - we covered that too.
AK IQ...
Your comment on roots blower belts had me looking a bit.. and found this interesting info on 11mm pitch belts
WOW... 800 hp just to drive the blower on a Top fuel car!
From here CLICK
NHRA supercharger drives are notoriously hard for belts to survive on. The application is extremely demanding, and requires a unique belt to perform as needed. The two top classes that use superchargers are Top Fuel and Funny Car. In a typical 1000 foot race, a Top Fuel car will have elapsed times in the 3.8 to 3.9 second range.
HP requirements to drive the supercharger are typically quoted in the 800 HP to 1000 HP range. This is with the driving crankshaft being around 8000 - 9000 RPM.
If it was just a question of handling 800 to 1000 HP, the drive (while large), wouldn't be that difficult to design to work properly. However, the system has a lot of unique load situations that really stress the belt. The torque fluctuations from the engine resemble barely controlled explosions. The speeds are high. The heavy loads make it likely that shafts will flex and belts will track to the outside flange edge. During tire spin conditions, drivers have to "pedal" the car. This is a method of getting off and back on the throttle very rapidly in an attempt to get the tires hooked up and stop the tire spin. When this happens, the driving RPM drops nearly instantly from 8000+ RPM to a couple of thousand RPM. The inertia of the supercharger takes over at that point and it tries to become the driving shaft. This creates havoc in the belt, as the tight and slack side spans in the system are reversed, creating high shock and compressive loads in the tensile cord. Add in the virtually instantaneous load application when the cars leave the starting line, and you have a very difficult, very damaging application.
An 11mm pitch Poly Chain GT belt was specifically designed for this application. The 11mm pitch gives more speed ratio flexibility than the previous 14mm pitch belts, and 11mm belts have more strength and ratchet resistance than 8mm pitch belts. A specially designed tensile cord is also used to handle the loading situations described above.
Not sure that Polaris is using a Gates belt though... which could also be a reason for change in durability when running their top quality PolyChain
The type of loads and loading conditions, high-torque and lots of on/off high-load, would be common between a sled drive and a blower drive.
Thoughts??
