Preferably in the northwest?
Pretty sure Specialty Sleds up here can do it
I had an 05 Rev with the P85 for a while and it took out two clutches in two weeks ! Broke right on the spline where it had been machined from the inside.
I did that in 2001 on a new 800 doo ,,the weight diference between the two clutches is HUGE and the rotating inertia of a tra VS a P85 acts like a harmonic damper since the flywheel and weight of the doo damper/flywheel is balanced for the TRA you will also notice that when you get the P-85 on there that it will not pull as much weght as you expected because it acts much like a lightened flywheel in a car, I broke 2 P-85s at the base of the threads where the spider screws down, fun to get off the crank, I even had a bilit stainless spider made to fit the p-85 to make the p-85 weight the same as the TRA then it pulled almost 6 grams more per weight ,then it started to come around and acted like I thought ,, then the crank end broke off, I think that the harmonics that are created are much larger than we know, the TRA has a large rubber damper on the clutch for a reason,,,,, THE END.........Thanks, that encouraging!I have it at Wilderness sports getting balanced, keeping my fingers crossed.
I wonder why the Doo's are any harder on a P-85 than a Polaris??????
another thing I tried on my race sled was to lighten the fly wheel for better aceleration ,,which it did,, then it ate clutch rollers and weight bushing almost every weekend ,HARMONICs in the rotating asy is a mystery?? Cat lightened the cranks on the 10-11 m-8 and I have seen many spiders explode including mine,, Could be the same effect!!!!! just a thought
I agree with you on the harmonics and with the issues on the 10's and 11's. My spider also shattered, what have you done to your's? Im thinking of trying another cat clutch and a billet spider.
Just buy a Pro. It comes with a P85 and a Team right out of the box.![]()
