Do you have a link to this can?
Do you know the price on it?
Weight savings over stock "suitcase"?
I have been running the Diamond S Quiet on my Axys all season with great results.
I am running SSI pipe mod into a Diamond S Quiet muffler with a PCV w/ Ignition module. I haven't got the mapping down right yet. I am running the the DTR non ethanol map for that setup. I am still getting a detonation code at WOT occasionally. It makes good power. I am running Belly Buster 66 gram weights with Carl's helix in the 42 ramp. It will pull 8500 RPM and more on the trail and 8300 RPM in deep snow pulls. Now, if I can get rid of the detonation issues, I will be a happy camper. It doesn't detonate in the ethanol mode but I would like to run it in the non ethanol mode. The SLP pipe works really well and no controller needed. I would probably do that if I was starting over.
I rode Kurt's Polaris 2017 yesterday.
His geardown kit, clutching and a Diamond S can.
That can was awesome. Sounded ALMOST stock.
It was quiet.
It's very small.
That sled HAS to be under the 400lb dry mark.
For the guys running the Bikeman Pipe and can without a fuel controller, how well is that working ????????
A lot of guys running the dynotech maps on the pcv have to realize that was tuned on a 15 axys. The 16 axys has 3-4% less fuel from the factory. This will make that map lean by that %. You have to add fuel to even things up or you still get deto. Not everyone may have that problem but just an fyi.
