Where to mount the boost controller
Where you can get to it. :)
What kit are you running, this will help for a educated response.
Most boost controllers have a pin size hole in them to vent off pressure to the westgate. This is how the boost controller works, by tricking the westgate that there isn't as much psi pressing against the actuator as there actually is. This keeps the westgate door more closed and increases boost. I've mounted a boost controller last year so it was accesible (sp?) and exposed to the environment and there was a few times that little hole would get pluged up with snow and your boost gets all jacked up. IMO put it under the hood to keep from running into this.
