Tonka1020 would you message me when you could ship me a ECU power up cable for my 2014 800 Pro R Rush, no big rush or should I say no hurry... Or if you like you could hold off shipping the $42.50 TPS testing harness that I order from you through Ebay & ship the power up cable at the same time...I am building the powerup cables now. They work on everything through the 2016 models. And it won't cost $20 to ship it!
I'll start working on incorporating the fuel pump plug next.
That combined with the pass through style tps plug seems to be the best way to tune and diagnose your tps.
And snowmow, I use a $250 fluke meter. They are solid and dependable. The Wal-Mart cheap-o's are pretty much a test light with numbers.. They trek you when you have power and the polarity, but not so good for accuracy!
Sent from my SAMSUNG-SM-G870A using Tapatalk
Ref from my earlier post:
Tonka1020 do you make a ECU power up cable similar to what SLP sells for approx. $30+ approx.$20 shipping???
This Power-Up Cable is used with an external 12 volt battery to provide power to the ECU and Fuel Pump of the CFI system. This makes it possible to check and adjust the Throttle Position Sensor (TPS) alignment between the Power Commander and the stock ECU without the engine running.
