I like to pull it out right before im about to go.... saves alot of money in the long run!!
I wondered if anyone else would go this route on their comment. I don't like to pull mine out at all, but i do to save money also.
When do you pull your sled out of the garage and get it ready for the season??
Would October 1st be too early??
What all do you do? I need to run all the fogging oil out of mine, clean the clutches, adjust the track, align tha skiis, and lube everything.
What else is there other than new plugs and belt!
Hurry up snow!!!![]()
Every year I swear I'll make a list of spring & fall service items but didn't.
Some of what you do depends on age & mileage but some general thoughts:
1 Check all track, JS bearings for rough spots. If they rumble, are rough change them now.
2 Adjust chain tension, change oil, synthetic is best.
3 Check carefully for loose nuts, bolts & loctite any that are loose, check track.
4 Check engine compression or do a leak down.
5 Lube hyme joints, grease suspension, steering, etc.
6 Check track tension, align track.
7 Set ski toe in, inspect wear bars/carbides.
8 Replace oil filter, drain carb water traps-if any.
9 Remove drive & driven clutches, clean, service, inspect carefully, replace parts as needed. Check alignment, belt side clearance & belt deflection. New belt & plugs.
Probably missed some things.
Change oil & fliter and check the boost gauge........it's a Yami..![]()
Hmmm... from first glance at this thread topic , My mind went way somewhere else...
Buy a new one in Febuary like i did and only put 350 miles on it before you fog it, grease it and polish it up and park it for the summer. Everything should be good to go except for what i broke. Anyone selling one gripper ski ??????
even when i snowchecked one i still had 10hrs on it before it even hit the hill. you know starting it, drinking beer and telling stories. i think i have had some of my best climbs in the garage. l.o.l.![]()
Been wrenching on mine for the last two weeks.
All that's left (Planned) is the chaincase.
But the snow show is in mid October and you never know what that will bring.![]()
i know what your talking about. every year i think i'm ready then i go to the show next thing i know i'm still wrenching the night before the first ride. ( that could be a poem)![]()
