... some people claim "clean" exhaust valves after x miles. Like J I run 32:1 mix in my mod and also in my other sleds via injector. I have used different oils over the years and never had clean exhaust valves. I have gone back to Klotz after a hiatus, and my valves get just as carboned and gummed as with the other oils. Just curious what people mean by "clean" in this context....jmho
No carbon, no gummy oil. Valves move as freely as the day they were brand new. I run pre-mix as well in my 800 mod. I've ran Klotz in my old 740BB mod, my 809 Triple mod, and my 800HO mod with no issues. I used to run amsoil until I noticed a lot of heat transfer in my wrist pins so bad they would discolor the metal. Got rid of that by switching oils. All of my engines were finely tuned as well. Not sure if that makes a difference or not.
Do you mean this stuff?
http://www.lucasoil.com/products/di...- Semi-Synthetic 2-Cycle High Temp Racing Oil
I know Lucas makes great stuff but, I must say this is the first time I have ever heard of their two stroke oil. Hum?
What?! No Klotz users??? I've been running Klotz for years. Smells good. I've NEVER EVER cleaned my exhaust valves and have about 3000 miles on my engine running 32:1 ratio. Smokes a little after a cold start but cleans right up after warm.
amsoil imo
My fave oil is the Quicksilver Semi-Synthetic. good protection, low smoke, barely any fouling and about $20 a gallon at walmart. Mercury outboards run it at WOT all day and very rarely do you hear of an engine popping unless you have plugged carbs or poor timing. very clean since it is designed for water use and makes cleaning powervalves very easy since the carbon deposits can be freed up easy in mineral spirits. I have a 2000 skidoo 700 twin with more than 6000 miles on it right now and am still reading 148 and 150 on both cylinders and have never done any interal engine work or even had to replace a seal. only an occasional carb cleaning and once a year powervalve cleaning. My other 700 sled I ran injex and did rebuilds every 1000 or so miles so I switched to amsoil and got 1500 miles on that rebuild now I am running quicksilver in that one and it is reading 2860 miles since last rebuild.
I'm on the Klotz with ya.
One problem running that stuff if you have oil injection, the oil isn't made to withstand real cold temps. If your premixing you'll probably be ok but I wouldn't use it.
I've been running Klotz for the last two seasons and really haven't found a better smelling oil but after reading indy dans thread about cranks I'll be running regular ol Castrol 2T from now on....no point in literally burning money.
