What's the ideal max RPM level? I'm hitting 8450.
So are you talking about on the trail or in the snow under a load(climbing)?
You should feel lucky...im only getting 8100. Have tried both complete Carl's clutch kit and an SLP clutch setup. Cant seem to keep the Rs up at altitude while climbing.
What are you seeing for track speed at that rpm?
My slp stage 2 155 track under load climbing in deep just screams 8500-8650 even hits 8700
5000' running 94 in non ethanol mode no resistor .
Not for me, last time out in the am was hitting 8250-8300 and pulled like an angry baboon, then later in the afternoon (after temps had dropped significantly) was hitting 8450-8500, laid over like crazy..
Mine is a BMP pipe w pcv, so fairly similar setup..?
I have the pipe/can and the stage 2 clutching. Mine seems to be 8350-8400 the majority of the time but I hit 8550 a few times also... And it retarded the motor twice on me. No codes, just let out of the throttle and got right back in it like nothing ever happened. Rev limiter? I'm running at sea level in the UP. I was considering switching to 10-72s (stock wants 10-70s) and seeing how they run compared to the MTXs...
If Running in the flatlands I would switch out the stock 40 helix.
can any of you guys that are turning higher rpm (8300-8500) please post some track speeds that your turning? looking for untracked deep snow pulls. not track poaching with 100 yd run at the hill.
both my 16 axys 155 2.6 sleds with slp pipe and carls clutching is 39-40 max mph. my sleds will not pull any more than 8150, run 8100rpm 99% time.
I see 42 min -46 mph ill check again next big deep day ,that was waist deep fresh powder.
for the guys that think I need heavier weights , I kind of like it there .. made some 850s take a second look where I was going .. then they left... he he .
3' of untracked on a good climb I'm seeing 48-50 mph. 8300-8500 rpm. I have a Pipe, head and porting done.
Last year my 16 with the factory 3" and chaincase (low gearing) with the SLP pipe the track speed was 40-42 on good long pull in deep snow.
I turned it 83-8400, drop the it down to 81-8200 and would loose 4-5 mph track speed.
My 17 has the 2.6 on it, slp pipe and geared lower then stock. Should finally get some good track speed numbers this weekend. Eric
