I got a completely stock 2008 Yamaha nytro mtx. I am planning on spending 3000 dollars on it. what would you suggest to do?
Track
Pipe
K&N's
Programmer
Front Shocks
if you only want to spend 3 grand i would for sure change the track to a challger exterme that is number one the maverick sucks. next change the rear suspension to timbersled skid lose 40 pounds and a better suspension and if you have a little money left maybe some clutching Those changes will make a huge diff on the nytro and then save up for a turbo
I would go with any header back system hauck, excell, there is also small shop making some to.
On mine I have an MBRP slip on and a hauck Header The MBRP is the loudest and sound great in the mountains.
I also have a challenger Extreme track with 8" big wheels and hauck K&N intake kit.
I'm not sure on what programmer yet.
For the front I have Fox Floats
I want to change the rear skid too ether timbersled or Kmod. I like Kmod as they build a heavy duty setup for 250 Lbs riders. As I am 6'7" tall 250LBS
The stiring relocation kit is great too
You say that you put the 8" big wheel kit on it. Then what size of track did you put on? And will the 16" wide track fit the tunnel? Also with putting on the Fox floats, will that stop the sled from diving unexpectedley?
