A blow off valve is a pressure relief, it is designed to open, and relieve charge air pressure when the throttle plates are closed under boost. This pressure relief prevents turbo surge. Turbo surge occurs when the throttle plates are closed under boost, the air supply to the engine is cut off, and the exhaust supply to the turbo is cut off. If the engine can not intake air, it obviously will not have air to exhaust. When the exhaust pressure is removed from the turbo, and charge air pressure is still present the compressor wheel is thrust back into the turbo housing. In a turbo with a journal bearing when the compressor wheel is forced back into the turbo housing a thrust bearing bares this load. In a ball bearing turbo there is no thrust bearing, the ball bearings would bare the load. The purpose of a BOV is to protect these bearings. However out of the hundreds of turbos we have sold without a BOV I have yet to see one damaged by turbo surge.
In the snowmobile industry a BOV is also said to enhance throttle response, by allowing air to leak from the charge area at idle, or with a snap of the throttle. It has been said that if the pressure is allowed to leak under these circumstances, the turbo compressor wheel will maintain momentum, and recover boost quicker. A BOV used this way is typically adjusted to be extremely sensitive by using a light weight spring. A diaphragm style BOV is also preferred for this type of use, because of its ability to pull open at idle. In fact a BOV set up for this purpose will often open under part throttle conditions, such as backing off the throttle partly when making a climb, or cruising down the trail.
A BOV is closed by a combination of boost, and spring pressure. The boost pressure that closes the BOV is supplied through a boost hose located on the manifold side of the throttle plates. This means that boost can not assist in closing the BOV until boost is being built in the intake manifold, then this manifold boost has to travel through a boost hose, and fill the back side of the BOV before assisting the return spring, and closing the BOV. The heavier the BOV return spring the quicker the BOV will close, and the quicker the turbo will build boost again. A light spring will close the BOV slower, in turn the turbo will rebuild boost slower. Under either circumstance the turbo will start to build boost before the BOV can slam closed. As long as the BOV is open you have a boost leak. Boost leaks are bad for throttle response. Claiming that a BOV will enhance throttle response could not be further from the truth.
We have an R&D team of the best riders in the world testing this stuff, and in every circumstance we have come across with a two stroke turbo, from drag racing in the east, mountain boondocking, the hill climb circuit, big shoot pulling, to even just pounding down the trail. Rather we add a BOV to a turbo that does not already have one, or we remove a BOV from a sled already equipped, the answer is always the same, no blow off valve= better throttle response.
You don’t have to take my word for it. Take your sled out, when its running good pull your BOV, and replace it with a block-off plate, you’ll see.
Junior
