What is the proper clutch combo to pull max rpm?
once again i could be wrong but i believe you have now mentioned three diffrent weights?:face-icon-small-con
1-belly buster
2-mtx
3-lightning weights
all the above are diffrent i believe and if i am wrong i am sure someone will castrate me shortly:face-icon-small-sho:tea:
k
so how does one check the tps? my buddys is doing this as well. 2010 800 155. had 10-62s tried 10-60s and still only 7600 rpm
i will pull the pipe here soon to determine the condition but if its not bad whats the how to on the tps?
mtx weights would be a good start. I switched to a carlisle belt when my 115 got old, liked it way better, especially for the price. simple thing to check, your throttle cable tension. The adjustment is about 6 inches down from the throttle, make sure you are actually getting wide open throttle when you think you are wfo.
my friends 09 dragon did this from the time he had the polaris update done .nomater what we did to it it would not pull over 7800 rpm.tricity tried clutching it another dealer put a pcv on it,pv springs 3 different cluch kits etc.still would not pull over 7800.put on kit from pms.got all the power and rpm back.removed pcv now pulls better than it has in years.the polaris pistons still look new but sled would not run with out fix :face-icon-small-hap
