What is the easiest way to change A-arms on...
you dont have to remove it,but it does make it easier to replace lower a-arm.i found that grinding a slight taper on the a-arm bolt threaded end helps it slide through the rear bulkhead bushing.
good luck D
I'm doing mine right now and its a pain in the a$$. I went through the top and had to pull off the battery, intercooler, fuel pump, and more. It be a good time to change your oil while your at it.
