SilverGriz
91 octane or higher is recommended. I run 92 octane in Idaho since that is our premium fuel.
90 is the highest you can get here in Alaska at most stations. Some sell race gas. I add 10oz of Klots Octane booster per each tank to give me 92.5.
Higher the octane smoother the burn. I have run red aviation a bit it is 100 octane and no lead. Your engine will last longer with higher octane.
Mini fuel lesson on AVGAS (aviation fuel)
RED AVGAS is
80/87 octane - (1 gram lead per gallon) and is being completely phased out replaced with
100LL BLUE - the LL stands for low lead (2 grams of lead per gallon)
100/130 - higher grade 100 ( 4 grams of lead per gallon)
Lead is indeed present in these grades of aviation fuel (TEL). The higher the octane rating the MORE LEAD IS USED. Lead is what they use to boost the octane. General aviation aircraft typically use 100LL now, as 100/130 has too much lead and the cheaper 80/87 is a lesser quality grade and being phased out. Light aircraft engines are designed to operate at continuous 75% power as opposed to sleds that operate a lot of the time at low power and idle, with bursts to full power. Also note that 100LL is just a posted number not the actual octane rating which can have a range from 91 to 96 octane
LEAD in your SLED from AVGAS will cause a build up of carbon on your spark plugs whenever you are at low power as the lead does not disperse and bakes onto your plugs, valves and other components. The AVGAS fuel itself is more refined and better quality than general road transport grades, and your sled will run good on 100LL as it does burn clean, so long as your are holding max throttle all day.
I run 91 or 94 pump gas (MOGAS)....and I do agree keep the ethanol out of your sled..
What is the octane level of the octane boost that you are running? The way I calculate it, the boost would have to be 300 octane in order for 10oz of the stuff to raise 12 gallons of 90 octane, to 92.5 octane. I'd like to see some 3rd party data to back up the claims made by these octane boost companies.
