Where you dyno'd the sled was not in minnesota. Bikeman is located in Osceola, WI
wich is 30 minutes from st-paul minessota!!!
and the highest temp this month was 97. I highly doubt it was 113 degrees in the shop.
http://www.weather.com/weather/monthly/USWI0523
you may highly doubt but yes it was, call and talk to Joey at bikeman.
I just ask that people stop misleading and try to keep the facts straight. PrecisionEFI you contradict yourself left and right.
absolutely not, that is such an easy and general reply meaning nothing,but since you are opening a door on misleading people, i think i will take that opening and speak a bit about a few things your company is misleading people about......No i won't hijack the thread, i will PM you in a sec....
Vipec ECU is a great product. I know several people that have used them on their import cars. If I had 2500 to spend on a fuel system then I would probably buy one.
good.
The manufactures Arctic/Polaris/Skidoo/Yamaha/Harley....etc all use ECUs from companies that spend millions of dollars developing a computer that can compensate for any elevations or atmospheric conditions. They develop timing maps that will get the most power and provide the safest running engine they can.
So what's the point?
The one thing that has always bothered me is how when people add turbos they do nothing to the internals of the engine.
and that's ok like that!! all manufacturer are building the engine internals very solid so they can go on for a long time, toyota sells the tundra at 381 hp and you can buy at the part counter a trd supercharger boosting your hp at 506 and still be on factory warranty and even 200 000km extended warranty. You will never brake a rod or a crank at 8lbs of boost if you tune it right and with real tuning tools, not a you know what.
That engine has a certain compression ratio which is defined by a squish band, cc of the head etc. and no one ever alters this.
and that is not requiered also, when again you have the right tuning tools.
The design of the cylinder has a direct correlation to detonation and how the fuel burns in the head.
again what' the problem??
Maybe instead of pulling timing to fix detonation people should look into alter the engine for a turbo
absolutely no need to change anything on the head,internals for low boost numbers....when you cannot control detonation no more or when adding to much pressure on the internals, then you alter the internals and/or compression.it as been proven a 2s engine from poo or ac can run forever at 8 lbs boost on pump sea level.......you need the right tuning tool AND THE KNOWLEDGE.
