2011 Silber Turbo kit.
Changed the low psi spring to the high psi spring in the wastegate yesterday. When the boost controller was turned all towards minus, i hade the same boost i was running on the other spring, about 5-6psi. But when turning the boost controller two rounds i should get 7-8psi in theory, but no difference at all. But when turning it 4-5 rounds it jumps to 15psi when giving it WOT, then it hits dET. Why does it suddenly jump this much, i would like to have it at 8-9psi. And what are the max psi on low psi spring? And the lowest on the high psi spring?
Thanks
Thanks
