stingray719
Check the link Christopher it was there...must be a site problemI saw it earlier, then it vanished
Lol, FAILED is the part I am concerned about too! But as the 2014 M8 has the same system as the Viper without a radiator I have some confidence it will work with ice scratchers. Might be a few weeks before I start work on this though.
The Arctic Cat Proclimbs (not the 7000s) have a combo heat exchanger which is comprised of a front heat exchanger coupled to a tunnel heat exchanger. The 7000s (and Viper) do not have the tunnel heat exchanger. They have the rad in front instead. If you were to remove the rad out of a AC7000 or Viper you will have to add to the cooling system somewhere else because it will not be able to survive with just a front heat exchanger.
2014 Cat M8 ltd have a front heat exchanger and no rear tunnel cooler as they hold ice and snow. With my radiator delete I have a similar cooling configuration as a 2014 M8 with 160 horsepower, and I hope/expect the 4 stroke to cool as well. Your opinion is noted though.
I'm guessing that MPI is using engine coolant to cool the center section of the turbo. Not sure if CAT is doing the same with the 1100T, but I would guess yes. This is my best guess as to why Yamaha decided to add the radiator, otherwise the cooling layout would be just like your M8.
I'm intrigued to see what MPI will do for a small tunnel cooler to replace the radiator...
When the snow becomes super deep and the Viper motor is under extreme load and sucking for air let the forum know what the temps spike to.
LOL! You really are clueless. Just so nobody thinks you actually know what you are talking about let me point out the M8/Viper have a heat exchanger in the tunnel. Snow goes on exchanger and guess what? It cools. If you manage to overheat a Viper or M8 in deep snow while moving post it here so we can put it on Ripley's Believe it or Not.
Deleting the stock rad is a waste of time and money. There is no way the bulkhead cooler will make up the cooling needed for this motor.
Did anyone consider they didn't use a tunnel cooler because there is just no room for it? Not sure if anyone has looked in the tunnel and seen the header pipe in there? Lol
Even if it does fit with a bunch of extra effort, there is no point when you consider the extra ice build imp from the heat exchanger.I ran a tunnel cooling system in my 14 last season with my 3". It's tight up front but the right cooling material will clear the header.
I couldn't believe how clean of ice and snow the Viper tunnel was last season. All other manufacturers have huge ice build up.
I would have to agree that this is a huge advantage. When I put my rear mount turbo on my nytro I could not believe the amount of snow that built up on the underside of the tunnel. I am deleting my radiator and putting a cooler in the back and hopefully keep the snow buildup to a minimum.
The lack of cooling in the tunnel seems to be the reason the viper did so well in the test snowest did last year. Who knows if this was purposeful design or dumb luck but it seems yamaha got this right.
I am curious however what the reason behind the radiator delete is. What are the benefits?[/QUOTE
The only reason I could see for deleting the radiator is if you needed the space for something else. Otherwise it makes no sense at all.
