Van Amburg heat exchanger removal kit ??
Does anyone know how the supplied plumbing lines fit into the Nytro, also we have their tunnel with the heat exchangers and need plumbing advice for these as well. One more thing, is the factory side tunnel heat exchanger used in this tunnel-heat exchanger removal kit....
Van Amburg cant answer this question, and I need help!!!!!!
pictures are worth a thousand words....................
thanks alot Tom.............:o:confused:
We used the VE tunnel cooler only.
Works great so far no over heating on hard pack roads .
I would also use the rad on my own sled .
Mine isn't the VE tunnel, but similar, and I eliminated the stock radiator and the little under tunnel heat exchanger (still have the bulkhead cooler) and temps are perfect. No cooling issues in 11 rides so far this year.
As a bonus, the rear cooler makes a nice hand warmer!! :D
I did the front heat exchanger delete and removed the radiator, and left the little one in the top of the tunnel with the u cooler with the crracing tunnel and no over heating problems.
