K
Kyle91rs
Ok I just bought a push pump gas turbo with a garret 2860 for my proclimb m8 from MMsports. Got an awesome deal, thanks Kevin. Just had a few questions and maybe you guys could give me some pointers as to what to do with this kit. I was thinking about running a boondocker timing key, ebc, and some sort of bov to get this thing into a little bit higher boost range. 10-12lbs would be maximum I will want to run. I would like to run straight avgas as I can't stand mixing gas!! I'm gonna be using it for revelstoke elevation so 6-9000ft. Does anyone see any flaws in my plans yet? I was wondering if it mattered where on the charge pipe a bov be installed, or if it matters, and what kind of bov would you recommend? Also, are guys having good success with routing their intakes up thru the hood? I'm not much for a sleeper look, that way I can gut my hood as well. Would you recommend using a/f gauges for tuning or egts? This is my first turbo setup, and i chose to go a cheaper route cuz i cant afford to buy a 6g+ kit right now. Figured i could buy this kit and upgrade as I go. What is the most boost you can safely run without a bov? I do have some knowledge on turbos to an extent but not as much as I'd like. Any help would be great! Thanks!
