Has anybody done a non turbo under tunnel exhaust on the Nytro? Are there any clearance issues with the suspension? Would like to see any installs or descriptions of installs, pro's, con's, problems, issues, etc...
I have seen some slip-on exhausts like Excell & such, but is all it takes is some tube bending and just mounting it up under the tunnel??
Thanks. I don't see why one couldn't just straighten out the pipe, use the stock muffler and do a Y out the muffler & exit out on both sides of the tunnel. Less expensive & no additional tuning. Any thoughts on this?
Nice muffler! I was thinking both sides just for the fact that while laying it over in deep powder you would not have any chance of plugging the exhaust regardless of what side you're on. Was thinking of stock to keep cost down.
Good idea on that bend. I'm sure you could find maybe a shorter muffler with a center exit. Then with a Y and bends like yours or even without the Y just using the stock muffler, and bend it to exit out the side of the tunnel right in front of that reflector. It should work & give you alot of storage space on the tunnel.
Looks perfect! Now, Just what brand / model muffler is that & will it work for the Nytro as in back pressure & all that??
