ok have an issue looking for outside suggestions
did a bunch off work on this sled last couple of weeks as follows
new tunnel, oil inj delete, Union Bay rv cover
fires right up idle 1700 range looks good crack the throttle responsive sounds great wont idle down below 3400 cover had a few usual grooves but measured .020 clearance over valve I know crank shop calls for .013-.015 going to check the boots and cover seal to case for air leaks anybody run into similar situation ?
may not have anything to do with cover sled was already piped and union bay head still run the HAC its good and recalibrated
on the oil delete I just ran a hose from the bottom fitting to the top and filled 1/3 of oil same as my UB 740 setup
