If you are going to run forged pistons you better know how to measure and set all the clearances up properly. You also need to understand what it takes to cold seize a motor. If you don't understand either one, you will destroy alot of cylinders and pistons and I recommend you stick will cast pistons. The pictures look to me like the clearances were a little to tight.
From my understanding. A cold seize occurs when the motor is not properly warmed up. The pistons expand faster than the cylinder walls. and Create fricton. Correct me if I'm wrong.
