I have and 09 800 Dragon. A had a huge burn down a few weeks ago. Busted skirt on pistons and cylinders. Busted cases and killed a crank bearing. EGT's gave no warning. I atribute the burndown piston slap clearence problems.
Got new cases, sent the cylinders into Mellinum tech for repairs and had the crank repaired. Used all new gaskets as well.
I installed the Wisco slightly oversized pistons the same diameter pistons as the FIX it kit pistons ( but not as long) .
The marks on the cylinder walls feel very light. Almost like a finger nail file.
The scuffs are porportional on both cylinders, mostestly were there are no ports.
While putting the sled back together, all parts were heavly covered in oil (including rings, pistion, bearing and cylinder walls).
The sled was warmed up to 100 degrees before moving. Additional Oil has been mixed in the gas. Its Running really heavy on the oil.
Plugs look a dark chocolte brown.
The last ride the sled was running really stong. Stronger 100% stock, than when I had my power attiction head and pipe on it.
While running I have been easy on it. Varing the throttle consitantly. No midrange holding. It has not been held full throttle longer than a split second, but only after an hour or of ride time.
Please help? Suggestions?
![d.jpg d.jpg](https://www.snowest.com/forum/data/attachments/116/116250-35510d14d87c50565ffd74d0f742f2f9.jpg?hash=NVENFNh8UF)
![1.jpg 1.jpg](https://www.snowest.com/forum/data/attachments/115/115342-37e6c058dbda61f4bf28c06ae131c2a7.jpg?hash=N-bAWNvaYf)
![2.jpg 2.jpg](https://www.snowest.com/forum/data/attachments/115/115357-e77606ee2c70c2620e89df1d576537fb.jpg?hash=53YG7ixwwm)
![3.jpg 3.jpg](https://www.snowest.com/forum/data/attachments/115/115369-eb18efb8e6e61fce3356c0ed561aed95.jpg?hash=6xjvuObmH8)
![a.jpg a.jpg](https://www.snowest.com/forum/data/attachments/116/116222-4930f6327de639a5e20bdc52ce377f45.jpg?hash=STD2Mn3mOa)
![b.jpg b.jpg](https://www.snowest.com/forum/data/attachments/116/116231-4981e37124e2c077ee12c980ff323164.jpg?hash=SYHjcSTiwH)
![c.jpg c.jpg](https://www.snowest.com/forum/data/attachments/116/116241-781647e544bbb596fa46a9b319a4b7bf.jpg?hash=eBZH5US7tZ)
