how much hp roughly at 15 lbs that must be a blast to ride,
compression ratio stock?
Kevin, also no timing mod.
I figured out my fuel gremlin. Bad o2 sensor showing lean! I will be back to 15lbs the next ride and report back compared to the 2876 at 15 lbs.
I'm ready for the report! My gtx3071 is suppose to be here today.
Stabbing the throttle from idle is approx the same. Boost builds very early. Climbing, the on/off response is basically instant. Very crisp sounding with a top end that you can't believe. I was running 14lbs @ 4-5k feet in 2-3 feet of fresh. Unbelievable. I had a return line restriction that was causing fuel pressure to build high at low throttle settings for the end of last year and the first several rides this year. Fixed that and was readjusting the box back for normal fuel pressure this weekend. I fought it in the low and mid till I added more mid-fuel and then got the wot fuel fine tuned.
It feels like 3 more lbs of boost with this turbo if that helps.
Hey Eli, You running race gas or a mix of ???????
Can wait for a report on this....what do you have currently?
I had a 2871 with a .70 ar comp. and a .86 tial ex. I am changing some other things. So it won't be a good comparison between the two. After I get it dialed in I am going to try and ride with a guy with a gt. So we can swap for a day and see if there is a noticeable difference.
