K
knuts82
On a dobeck you can input a given rpm and it will output a set amount of fuel depending on where you have your setpoint. On a PC5 it will add more fuel than the set program if your charge temps rise (ect.) to compensate for heat a dobeck box has no feed back to determine what the motor is doing. If your motor is hot and your charge temps are high you get the same amount of fuel as when the motor is cold and charge temps are cold since it is only based off rpm. The powercommader changes from set program using temp and A/F inputs. The box is only outputting fuel based on rpm input and its original programming no more no less. If im wrong please tell me how the dobeck box is load sensitive and not just rpm sensing.
