I would love to see a SC run good. They are definately fun to ride with the throttle response being like a 2-stroke. You guys getting them figured out will help alot of unhappy people!
rode my stage 2 sc all winter and absolutely love it. the problems ive heard of were solved before i hit the snow, (fuel system, clutching, and pulleys coming loose), i do check my pulleys every ride, no issues yet, power is unreal, bottom to top, slaughtered a turbo m8 last weekend, but i guess i should. to keep my rpm perfect on a long pull i overrev once when i crack er at the bottom. putting on my o2 sensor yet just to see if there is more room to work. as far as saying a turbo will beat a sc is pretty broad statement, bring it on, but it better be more than a 230 hp turbo, or it'll be lunch. a WELL designed turbo is only marginally more efficient than a sc, and after that, boost is boost. if your maintaining your boost through a long pull with 15lbs of boost on a sc, your turbo will still need over 14.5 lbs to compare (no head shim). as far as race fuel, its worth it for me but i can see why some people would like to run pump fuel and if 230hp is enough, then, great! I have noticed that if your helix isn't adjusted right, rpm will drop terribly on a long climb i usually change it once in a day of riding and usually takes about 2 minutes. either way, you'll have a blast.
I agree...I'm absolutely loving mine also.
I'm also seeing some drop in R's on long pulls. Got my shockwave screwed all the way in (lowest angle). Next I'm going to a stiffer secondary spring.
upnover, would you mind sharing your secondary settings? Shockwave settings, spring, spring settings, etc...THANKS!!
modsledr
had a chance to hope on a sc nitro this year for a little rip and man was it responsive! Unreal the way it jumped outa the hole, that said the owner said he had done all the r&d himself. He said the way they told him to set it up it didnt work at all. Lots of probs he said getting it to were it was. People generally have rode a rear mount nitro turbo when they talk about lag, hop on a impulse or a alpine kit and see how responsive they are. Not quite as jumpy as a s/c, but they will work great everytime you turn the key.
are you stage 1 or 2, i am stage 2, stock secondary spring. as far as hole position, not sure anymore. it is very important that your shockwave is 1.5 turns out in the mountains, great angle. get your weight right first then 1/2 turn in or out depending on snow conditions. i think you have too much weight out on your tips. i tried dalton weights, too much tip weight, overrev like crazy off the line then fall on its face. these things just have such awesome power down low that turbo clutching doesn't work on them. went to stock weights with 4.5 gram rivits in both the inner hole and middle hole on all 3 weights (of course) leave the outer hole empty. e&s motorcycles near edmonton are brilliant at tuning these, call darren at 780-997-3818 they will give you spring settings. was told by mpi that with fuel upgrade it would be very rich at idle, and to change factory yami settings. did this and wouldn't idle very well. stuck the o2 sensor in the pipe for a quick check and wow, very lean at idle. tuned it a little and wow what a difference. welding the bung in the exhaust tommorrow to install o2 sensor then see where its been running. im thinking if i can gain a little more power on top end i can back out the helix .5 turns and not overrev at the bottom of the hill and still hold perfect rpm on long climb. right now i overrev once when i crack 'er at the bottom then she settles into her prime for the long pull. if you cant get ahold of anyone, i can pull of my shockwave and tell u what holes the spring is in but if your stage 1, it wont help you. there is a lighter spring in my primary also for earlier engagement, my 10 yr old idles this thing around the yard, and climbs some pretty good hills at mcbride, very rideable even for a 10 yr old.
upnover,
Thanks for the info. Mine is also a stage 2. It was set up for the original owner who lives in Northern Idaho and rides mostly light, fluffy pow. Unfortunately, our snow in western WA is heavier, so I'll need to make some adjustment. If I start on hard pack, it hits about 8900-9k. As soon as I get in the deep snow, it drops off to 8200, and track speed drops to about 55mph.
Seems more like a helix/secondary spring issue, since I'm hitting my R's on the hard pack and roads.
thanks again,
modsledr
