So here's the background...
2006 Apex, MCXpress turbo 4200 miles. For the past two months the sled has been using oil. Probably put in 4 quarts over 20 rides. I thought the seals in the turbo were bad because it was blowing oil out a loose fitting on the wastegate side of my turbosmart boost controller and also blowing oil out the top two small hoses that come off the top of the intercooler. But it hasn't been consistantly using oil. Sometimes I'll ride several days and not need to add any. Some other times it uses a quart in a single day seems like. And I haven't rolled it either.
So last ride out, sled is running fine for first few hours of the day and then starts bogging when in a wide open pull. Clears out sometimes, other times not. Throughout the day the bogging gets worse. Gets to the point where it develops a low end bog that is has trouble clearing out. Now it's puffing black smoke out the exhaust, the side of the 5 gal can on the back was black after about 30 miles. Get back to the truck and it's worse than ever. Now it won't idle. Have to give it gas to keep it running. Shut it off, start it half hour later to load it up and it's running on two cylinders and flashing a code. Don't remeber which code but it was either 33,34,35, or 36 which are all...
"Fault Ignition"
"Open circuit detected in the primary lead of the ignition coil"
"Cut the injection of cylinder in the same group with the cylinder that the error is detected."
So I pull the turbo apart thinking it's dumping oil. But it's bone dry on the intake and exhaust sides. Pull the intercooler and there is no oil in it. Only traces of oil are in the two small hoses off the top of the intercooler. I capped these off with a zip tie so I think the oil has been there since I first found it blowing out oil there. No traces of oil anywhere else.
So any ideas what could it be? Does it sound like a oil change and fresh set of plugs would be the answer? Still don't get why it's been using oil and why there was oil blowing out on the loose boost controller fitting and the boost leak on the two hoses off the intercooler. How'd oil get in there.
Any ideas?
"Fault Ignition"
Any ideas?
