2018 Axys 163 2.6" w/ES
Stock pipe with SLP "quieter" can. Still too loud for my liking.
Primary 64 gram (weighed) stamped 62.5 Lightening weights with stock primary spring 120/320 and 2 thundershift shims (top and bottom of spring) and running the 1183 PI Belt shimmed to exactly 0.030" belt to sheave clearance.
Secondary: I went a little different. 42/34 F with venom reverse cut and 125/175 spring with a Team Delrin under the cup. Aligned and running 0.072" float. The other cut is 40/34 F. Haven't tried it yet.
At 6,000 ft. she pulls hard (8,250-8,300 RPM)in 3 feet of heavier snow, upshifts lightening quick and downshifts great when needed. Engagement is around 3,900 RPM.
I may try a 100-200 secondary spring. If you were going to nitpick this setup for absolute perfection, getting the CVT to stay and hold low range for slow speed, downhill engine braking would be the only thing you could find with this setup on this sled. It upshifts so quickly that I think it could run a little more spring and be absolute perfection.
I hope that doesn't upset Justin.
Now we just need some weather.
