That looks bad . poor clutching set-up and gearingA pic of a buddy sled. I mentioned it isn't shifting out and yur secondary could be out of alignment.
Response was a mountain sled never shifts out and it's fine. It has such an such cycle Clutching.
N/A 2019-850-163-2.6
Received another shipmentView attachment 336906.
You can also purchase my bar from Indy Specialties.
Yep, You don't need to match the exact amount, but you want to make sure you have .020-.030 float after installing the washers. If you didn't check how much float you had before you shimmed, you might be adding more or less than what you added to shim the secondary.so I aligned my clutches last night using the TRS bar my buddy owns. This is the first time I have done this. I followed the video.
my secondary was .145" out (or in). I added that in shims behind the secondary. brought it right out to the bar.
adding that .145" to the bolt float washers puts the stack at .339" total. does that sound right?
in order to achieve that measurement, I had to mix and match the float washers since i could just not add the correct amount to what the factory had in there. i think i removed one of the thinner factory ones, and added one of the thicker ones i bought.
everything seems correct.
does it sound correct?
Mine was similar. Just remove/add your float washers to achieve .020-.030i did not check float prior. If I am checking it correctly (using a feeler guage), it seems like I have more than .030 float after. ?![]()
...Installed the full TRS clutch kit as well, see how she runs this weekend, I hope.
