Trailer heater instalation
blizzard
New member
I am installing an 19000 btu 12v lp heater in my trailer and my question is - on the back of the heater it says elevation 0-4500 . Will this work in places like centenial , TML or do i need to put a smaller orafice in the heater or can i put an adjustable regulator on the tank to accomadate lo and high altitude at the same time ? Or will it simply not be a problem ? Anyone who has overcome this problem , your input would be greatly appreciated . Thanks
I'm sure you know to do so, but make sure you vent the trailer well. Carbon Monoxide posioning is serious ****.
Yup , I got her all vented outside ,it works great . I checked with the manufacturer and he said it should work fine - it might smoke a little and not run quite as efficient though , and if i wanted to put a variable flow regulator on it that it would only take about 1 lb less at elev and would be sure to run fine then . A local gas man told me the same thing , so I guess I should be set . thanks guys
