per your example Ot..both the short track and the long track loose track speed when you back out of the gas..the difference is with the longer track it is easier to recover the lost ground speed....both sleds will recover their track speed when you gas them again...but only the long track is able to pick back up its ground speed..both have track speed..but the short track lost its ground speed.. on the gas its not floating that is saving the long track..its the amount of hookup that keeps it moving..(easy to prove too ..just compare a widetrack 15+156+1 1/4 track to a camo extreme 15+156+2.5... at slow speed with no track spin the long track is getting around by "floating on the snow"..but on the gas it is all about the amount of hookup provided by the track....
By the way CC the pic your looking for was a Viper Mod buried to the hilt while 12 guys waited at the bottom and never even made an attempt.
OT
Without TRACKSPEED everything else is just a mute point.
OT
There is no ground speed when your floating through 3 feet of virgin dry fluff...It's just not possible to be floating and on the ground at the same time. There really isn't much traction either to be had in virgn dry fluff....
Long powder tracks are designed to fan the snow from both sides of the track when riding in virgin fluff. The only time traction enters the picture is when your riding on a firm base or icy base and a powder paddle track sucks on a firm base or icy base.
OT
Heres a better comparrison...sparky
Turbo Nytro with STOCK track vs a properly clutched/tuned stock XP in a "chest deep" powder day....
nytro track speed was showing 70++...
XP hanging around 45-46...
I know the answer...cause I was there...-BJ
FYI- this comparro is like drag racing sleds on ICE...one with trail studs and one with ice piks...
DUDE...so if theres "no ground speed"...then your stuck or hav'n a samwich...
DUDE...if I read this right...track lug height is irrelevant in powder??
Please stop...your even making yourself look/sound bad....please...BJ
Don't bring up this don't bring up that....Like i said CC i on't know what deck of cards your playing with Bud ?
Are you trying to say you've never been buried to the hilt ? Come on CC who are you trying to Bull Sh!t ?
OT
That "Viper" couldnt climb squat...a bunch on flatlanders were riding with you that day...YOU were stuck on flat ground...LOL
YOU my friend are lieing out your backside...BJ
the only reason you thought it was steep was because the back end of the sled was 8 feet lower than the front -
Just FYI for you,better doo some more researchCC, after doing some research on ground speed it's what aircraft pilots use to measure air speed based on a fixed point on the earth. For instance if you ever flown on an airplan that has the TV screen mounted on the back of each seat the TV screen will display a fixed position on the earth to determine the speed of the airplane, Wind speed can and will have an effect on an airplanes speed as it's relative to the ground speed.
So CC again how does ground speed of an airplane come remotely close to trackspeed of a snowmobile ?
This should be good. LOL
OT
