What's the best way to set your track tension if you don't have the tension tool? I have an 09 Ski Doo XP 163
push down on the middle of the track,,, 15 lbs should be just over 1 inch. Dont forget,,,, loose tracks are slow.
Loose tracks are slow? I thought the idea behind extroverts was so that you don't have to run the track as tight so you gain hp to the ground...
