Track question
G
gotthefever
I am in the process of making my 99 RMK 600 136 into a 144. I found a 144x2 track but the pitch is 2.25. Will this track be to heavy or will it work fine?
Thanks
The Drivers will also have to be 2.25 pitch to match up that track. They are fairly simple to change out if you have access to a press. Just make sure to get your measurements dead on or it can get frustrating. Or you can just look for a track that fits your existing drivers.
Just what I've learned from my experience.
track swap
I would be more concerned about your 600 being able to pull the 144. You are more than likely going to have to change gears, weights, springs and helix. Just my two cents. As for the pitch change, new drivers yup!
The Gen II RMK's had 2.52(I'm assuming he means 2.52 since there is no 2.25) drivers so no change is needed. Rail extensions, a tunnel extension, track, gear down and go. You'll love it. The track weight won't be an issue at all.
