track porting
Mine is ported with one hole down the center...I think I'd do two the next time. Seen some guys running with 5 holes (3in the middle and 1 on each side)...also found a shredded track with 5;)
who has ported there track and how many holes
Porting is personal preference.
On the 900, I did two down the center where the idlers don't run.
Did you use a hole saw to cut the holes? Thinking I might do it if its not too labor intensive.
this is how my 05 900 166 track was ported by the previous owner...been great for me...
do u have any issues with vibration when the wheels run over the holes i was thinking about running 3 down the middle
porting
I used a hole saw and it worked great, i did a 1 1/4 hole. After you drill the hole out just take a tourch of some sort and burn the inside of the holes to keep it from fraing. I learned that from some body on snowest, you can also burn any other fraise you may have on the track.
This is exactly what I did. I run an inside wheel kit, and one is all you have room for. 1.25 hole saw works like a hot damn!! Doing this, you only shed a half pound of rubber, but it's more for letting the snow out.
Just make darn sure you don't set the track on fire! I read a thread about this same time last year that a guy was burning some loose threads on his track, came back about a half hour later and had a soft-ball sized section of his track melted away!!!! from a thread that had continued to burn....:eek::eek::eek:
might be a good idea to have some water handy just incase!:eek::eek:
If you use a hole saw grind the teeth flush on the outside and it will leave a smoother hole.
