Track clearance
turbonium
Is there more track clearance on the 13 pro than the 11-12 pro?
What about the 13 assault? And std rmk? Is there any difference in track clearance? I want as much as possible.
that's a good question I wouldn't think so though nothing on the skid was changed on the 11 and 12 they have different lengths of suspension on the front but I believe its all the same hope this helps!
There is / was no change in the center to center distance of the jack shaft to drive shaft since the Pro Ride / RMK chassis debuted with the Rush in 2010. Both the chaincase and belt drive are 191.26mm / 7.5299". So the only potential difference is the front cooler on the models that have the front tunnel cooler, but from photos of that front cooler on EBay it looks like the tunnel side is the same dimensionally and the water is offset into the engine area.
So the short answer is absolutely no difference on any of the sleds as to track clearance in stock form.
