R
rockymking
FACT, when you click your clickers down from #5 to #4, #3, #2 or #1 the centrifical force as the primary rotates at entitle startup will move the ramps down from #5 to your selected #4, #3, #2, or #1 clicker position.
OT
This is a true fact ... the ramp will be pushed by the roller arm assembly until it contacts the eccentric radius of the clicker bolt, where it will remain stationary against that eccentric radius until another clicker adjustment is made to a lower clicker setting. In my TRA VII, the pivot point of the ramp is fairly snug, so the ramp is not just going to "fall" onto the lower radius after lowering a clicker setting. If you increase a clicker setting, there will be NO movement of the ramp at initial startup, since the increased radius of a higher setting is what pushed the ramp up. The movement is going to start and finish in milliseconds and then it's over!
Tell me this is not what this whole pissing contest is about??? Semantics and technicalities about ramp movement during a clicker adjustment that last less than a second? You must be really bored
