simbatheking
Well I'm really happy that my issue is resolved. The bog/fall on its face issue was caused by not enough weight in the pins and what resulted was there was not enough heat/back pressure to spool the turbo up fast enough and fuel would dump in before it could build boost. I'm back to the 2mm oversize rollers and had to add an additional 4g on top of the 3.4 g that the bigger rollers add. I'm back to my titanium spring which Renton has confirmed is a 130/290. Today I tested it in some very heavy snow which just got rained on and with the 3" track I could pin it from a stand. Still and instantly almost flip the sled straight backwards if I didn't let off the throttle. My only concern is my shockwave is still at about a 54 or so deg angle. My primary stays cool enough I can keep my bare hand held on it but the secondary is hotter for sure. Sorry didn't have the temp gun with. Should I change the sec spring? I also love the lower engagements with the big rollers. Way better fuel mileage on trail too. I'd rather not add any more pin weight if I can avoid it
