I'll try to keep this short - I just had my sled in for it's 10hr check up and came back from the dealer with added pin weight, went to double the stock length or weight, how it is measured exactly I don't quite understand. So, from stock of 12mm to now twice that. Didn't change anything else, set to clicker 3. I headed up the groomed trail and after warm up and at the first long straight stretch I cracked it, 7500 rpm, next straight I held it to the bar, 7700 rpm. I knew right then it wasn't going to work, as I think you should be able to over rev on the trail with a good mountain set up. First hill confirmed it, heavily traveled and really compacted hill climb, sled came over the top at about 7400 rpm. Clicked it up to 5 and did some lake drags, flat to the bar on the compacted lake 7900-8000 rpm. Played on one big hill with fairly set up powder snow, about 15-20cm's trench depth when climbing.....couldn't get over 7800-7900rpm. Here's the thing - saw 77km/h track speed for the first time ever on a hill climb. With stock set up in deep/dry snow on clicker 5 I had seen 75km/h.
So I was happy to see this track speed, and I also really liked the way the sled upshifted, pulled hard, put me back in my seat and got the skis off the ground like it never could before when stock. Also, at an idle through the trees or maneuvering through compact trails around creeks and stuff, slow speed riding, I dropped a lot of rpm, would guess at 6-800. Didn't work the sled really hard as it wasn't a deep day, but all in all I would guess the clutch was cooler.
Now the question - where do I go from here? Would love to keep the low end grunt and would also like to keep the belt shifting as high in the clutch as it was (1/2" or so more than when stock)....should I gear it down and click down to 3, knowing that on a deep day I could click up to 5 or 6 and for long trail rides I could click down to 1?
Is this too much pin weight to start finalizing my set up? Should some come out (15 -16 ish) before playing with it further?
nate
