tra clutch question
B
born2sled
i have an 07 rev and wondering my sled rpm's even at not much throttle is really high last year i was at really low rpm's at full throttle so got the dealer to make pin weight less to try to increase rpm's but later found out it was the solenoid hose off that was causing low rpm's. but the pin weight was taken down still, anyway my question is can i just by set screws from the hardware and add some to my clutch, to make pin weight right cause i sure have to go slow on the trail or i will be over revving i even have the clickers on 3
Yes, any set screws with the correct thread will be fine. You'll want to be at 83-8400rpm on clicker 3 ideally.
Hopefully you can zoom into this.
There are two brp pins as of lately.
