torque specs
M
MacDawg productions
just need a few torque specs guys.
1. rear motor mounts
2.front motor mount cross member bolts (4 of them)
3. engine bulk head side plates
Also, anybody know of an easy way of getting the freakin pullstart recoil spring back into place after replacing pull rope?? I just spent an hour and 2 :beer; trying to get it buttoned up!
this is all i could find. they don't list those bolts under torque specs just the engine ones hope it helps.
and yes that recoil spring can be a bugger :(
You probably know this and it just came out on accident...... But the spring doesn't need to come out to replace the rope. Yes, it is a sumbeetch to get back in, take it to a bench and get it wound back up there and use a small vice grip to hold it together while you place it back in the housing, makes it a little easier to do when you aren't fumbling with the housing at the same time.
