D Desperado Well-known member Jan 20, 2011 #1 Looking for the torque specs to the cylinder base bolts, cylinder head bolts, exhaust valve bolts and the y-pipe bolts. Rebuilding the motor and any help would be appreaciated. Thanks
C canj Member Jan 20, 2011 #2 Fastener Torque Guide Spark Plug 18 Ft. Lbs. (24 Nm) Apply Nyogel Head Cover 25 Ft.Lbs. (34 Nm) Loctite 242 Cylinder Head Bypass Fitting 7 Ft.Lbs. (9.5 Nm) Bleed Screw 70 In.Lbs. (8 Nm) Knock Sensor 168 In.Lbs. (19 Nm) Clean and Dry Temp. Sensor 18 Ft.Lbs. (24 Nm) EV Housing Base / Cover 12 Ft.Lbs. (16 Nm) Loctite 242 EV Bellows Nut 16 Ft.Lbs. (22 Nm) Apply Loctite 2760 to the first 3 guillotine threads. Cylinder Base Nuts 37 Ft.Lbs. (50 Nm) Cylinder Bolts 42 Ft.Lbs. (57 Nm) PTO Crank Seal Guard 12 Ft.Lbs. (16 Nm) Intake Boots 9 Ft.Lbs. (12 Nm) Exhaust Manifold 22 Ft.Lbs. (30 Nm) Oil Pump 7 Ft.Lbs. (9.5 Nm) Water Pump Cover 9 Ft.Lbs. (12 Nm) Recoil Housing 9 Ft.Lbs. (12 Nm) Recoil Hub 9 Ft.Lbs. (12 Nm) Flywheel Nut 90 Ft.Lbs. (122 Nm) Loctite 242 Magneto 12 Ft.Lbs. (16 Nm) 5 Ft.Lbs. (7 Nm) Loctite 242
