Torque Arm for CFI 800??
Hi.
I'm looking for a torque arm, (front PTO side), for the CFI800 in the Assault, anyone seen a solution for this? SLP doesnt make one....
Suspect that the problem is that there is no place to bolt it to the engine, the elektric starter gear mounting is too weak since it wont even hold that without failing, (bolts broke on the D7 with e-start I had).
Thanx / Simon
torque stop
The one Carl's sells needs to have a hole drilled and tapped in a boss in the case below the e start. That's why the motor needs to be removed. Not enough room to do it in the chassis.
Is Carl's selling the Fire & Ice unit or something different??
