I had some light scoring on the cylinder that didn't get the skirt broken when the engine went down last spring, but it wasn't very deep (could feel it with a finger nail), so I was curious if I could make it work. Reading on here, seems like everyone has enough money to not make that kind of gamble without batting an eye. With some of the guys driving across country to ride, I don't blame them, but when I drive 40 miles to ride and don't make much $, I'm ok with a little experimentation.
The first pic shows the cylinder with light scoring that I bolted back up this fall. I rode with that about 5 miles in November on the MAG side, with a lightly honed cylinder off Ebay on the PTO side. New pistons and rings, rebuilt crank, SLP head, SLP twins. After a couple miles I checked compression. 110psi on PTO side, 92 on MAG side (pretty high up, thus the low numbers). It ran well, but I didn't like the numbers. SO I figured I ought to tear it down and have a peak. I figured either the light scoring was causing compression loss on the MAG side, the cylinder was not true/straight, or the rings were not seating because I didn't run a hone thought that cylinder.
I ordered a Flex Hone, 240 grit meant for Nikasil. Ran the hone through both cylinders, washed them, put the motor back together, cylinders on the same sides as previous assembly, checked compression (oiled cylinders but cold) here in Laramie. PTO 120psi, MAG 102 with WOT and 5 pulls. So still uneven. Pulled cylinders, honed the MAG cylinder again (pic of that cylinder is shown below). This time when I reassembled I wanted to see if the poor compression followed the cylinder of if it was because the rings hadn't seated on the MAG side. The Ebay cylinder went on MAG side, my old cylinder that I have now honed went on PTO side. PTO compression 120, MAG 102. So the poor compression stayed with the rings that didn't break in. Good news for me. I suspect the compression will become even once the MAG rings seat now that they have a honed cylinder to break in on. I'll report back after a break-in ride, but I'm waiting on SS exhaust valves on a clutch cover bushing.
Anyway, just thought I'd share, because it seems like few on here ever try to save $ on stuff like this for fear of a wrecked trip, which is understandable, but makes it hard to get any idea of what corners can be cut to save cash.
Oh and I didn't have the pipes on doing the compression checks in Laramie, I imagine that drops the numbers down some too.
For the record, oil lines go over the carb boots, and that's how I have them routed.
http://www.polarispartshouse.com/oe...-s04nk8cs-a-b-c-s04nl8cs-a-b-c-s04nm8cs-a-b-c
This link shows the OEM orientation of the oil line hoops, over the boots, just zoom way in at the carb boots. But as Hardass pointed out, and Jay explained in a PM, it wouldn't matter either way. If the case fills with oil, the check valves are bad.
