So notice a cracked in spider so go to replace. Literally starts ripping g the spider in half.
I tried to repair cracks with puddy kb weld, then tried water trick, filled with water, plugged off primary and....it just split the cracks again once water froze.
So them I drilled holes in the outter, through to the inner amd bolted the 2 sheaves togther. This time, it just broke the otter sheave and I ended up just pull it apart.
At least now I can see the crank end and should be able to cut it off.
Anyone else experience anything like this?
