For next time get some of this and apply to the snub shaft of the crank
In any taper/taper fit drive assembly... if that is a boat prop or a sled clutch... regardless of brand... the tapers, both internal and external, must be CLEAN of any rust, Clean of ANY oil or residue and DRY before assembly.
Never use anti-seize, oil, grease, corrosion inhibitor, loctite, or any other compound in there PERIOD....Regardless of brand of sled or clutch.
If the bore or the shaft is grooved... you have big problems that must be remedied.
