Torco Mach Series Accelerator ?
Givemeaboost
Does anyone have any experiences with this product ? I'd like to hear the good and the bad as for how this stuff has worked for you. I've been running it for the last six times and so far so good. I'm running up to 20# boost for short drags and 15# for trail riding and it seems to be working alright.
The stuff is pricey but works. you need a 32 oz bottle to turm 1 tank of 91 into 100 octane. It is basically concentrated race fuel & not an additive which don,t do squat anyaway. This stuff is for real. i used it racing my turbo & no burn downs.
I bought 5 gal. of this stuff and called Torco and talked to the the guy in the shop. He told me that 32 oz. with 5 gal. of 91 octane will give a true 105 octane and by using this amount with 10 gal. of 91 will net you 101. Places that have 93 octane can get up to 107. I even asked if you can go higher ratio than 32oz. to 5 gal. to get more octane and he said that it actually goes downhill with a higher than reccomended ratio. One good thing about this product is that you use unleaded premium and this has no lead so oxygen sensors should last longer, Ken.
I have been using it, mixing 2 oz. to every gal. should be about 95 octane which is plenty for my mcx kit with the shim at 15lbs. for $200 I can treat 320 gal of fuel thats alot cheaper than race fuel mixing 50/50.
Is that all the octane you need to run 15# ? What elevation are you running at ? I'm running at 7000-8500 ft and have been mixing it to get me at 105 for 18#. I have 10-1 Wisecos in it. Do you think I'm wasting my money with this high of octane. I've tried to figure out that octane calculator but the figures don't seem to come out right, Ken.
Is that all the octane yyou need to run 15# ? What elevation are you running at ? I'm running at 7000-8500 ft and have been mixing it to get me at 105 for 18#. I have 10-1 Wisecos in it. Do you think I'm wasting my money with this high of octane. I've tried to figure out that octane calculator but the figures don't seem to come out right, Ken.
according to the boost calculator you need 96 octane at 7000ft. at 18 lbs. with 10.1 and one stock head gasket. you need to put in your gasket thickness it has the apex in the box the rx1 is .025, and starting compression of 10.1 should give you the info you need. if you have more than one gasket just add another .025 to that #.
